How do you jump start a Dexta
Tom
03-02-2002 05:01:35
I have 62' Dexta. Hopefully the battteries are run down because of lack of use this winter. It has two 6 volt batteries in series to make 12 volts. Can I jump start it with a 12 volt system(ie.. a pick-up truck) or will I cause damage?
henning thomssen
03-02-2002 08:32:06
 Re: How do you jump start a Dexta in reply to Tom, 03-02-2002 05:01:35
Two 6 volt batteries hooked up in series gives you 12 volts,my dexta has a 12 volt system,i believe they all came that way.If two batteries are hooked up parallel,then that gives double the amps with the voltage remaining that of one battery.so, go ahead and jumpstart with your truck
henning thomssen
03-02-2002 08:36:12
 Re: Re: How do you jump start a Dexta in reply to henning thomssen, 03-02-2002 08:32:06
Sorry,i guess you already knew that,but just the same,use the truck.
