Fordson Mystery????
Trenton Dobbs I
02-14-2002 21:13:52
Found a Fordson tractor which i thought to be a 1918 or 1919, because of the ladders sides on the radiator but it has 7 spoke rear steel and five hole drawbar and it also has fenders with toolboxes in the rear. Where is the serial# located on this tractor. And is there any other way to identify the year. Any help would be greatly appreciated. Thanks Trenton Dobbs B.C.
Paul
02-25-2002 12:32:06
 Re: Fordson Mystery???? in reply to Trenton Dobbs III, 02-14-2002 21:13:52
Sounds like you have a very desirable Irish long wing model,but with the wrong rad on.Look above the first manifold port to find serial no,or see where tractor was made and I will give you a rough date of manafacture.
fordson exchange
02-16-2002 08:34:48
Trenton,
Almost all parts were interchangeable on the Model F. Yours could be a Frankenstien. The serial number if it has one is on the front right side of the engine over the first exhaust port of the manifold.
