Re: '55 Fordson diesel 45hp, Fuel problem!!!
Steven B
02-05-2002 14:23:53
I hope you mean Diesel and not Gasolene. If you put gas/ petrol in the tank, dont atempt to start, the engine will self distruct.
Anyway, there are two 1/2 in screws on the top of the fuel filter (that metal cylinder), slacken the rear one of and work the lever on the lift pump untill diesel flows with no air bubble. Tighten up (dont over tight, they strip easy). Repeat with the second screw at the front of the filter. There is another similar screw on the injector pump just below the injector pipes. Bleed that one. The tractor should now start but you need to allow time for the pump to get the diesel up to the injectors
