FS Major Problems Help Brian
David Mattox
02-03-2002 17:27:40
My 63 FSM Has a Smoking problem Which is apparently not an oil smoke because its Black smoke and i'm not losing engine oil i'm gaining it! or diesel leaking to it? i removed the valve cover to check the inj overflows and found 4 Severely bent push rods! {I just purchased the machine and guess ive been running on 2 cylinders}
i straighten those and reajusted valves and it runs much better. but still smokes!I'm guessing that someone previous ran the machine with the Decompresser up? The link between the injector pump and the timing Mechanisms is loose is this normal? any help is appreciated!
Thanks David
