Fordson Dexta Front Axle Pin
Todd Allen
01-09-2002 21:01:06
Hi! I am in need of a front axle pin for our 1959 Dexta, I have been trying to find a new one but it is no longer available in the US I would even accept a clean used one if it can be had, any help is appreciated thanks!
Todd
Burrhead
01-10-2002 17:41:34
 Re: Fordson Dexta Front Axle Pin in reply to Todd Allen, 01-09-2002 21:01:06
Todd there's nothing special about the pin dimensions. If you can't find one at a bearing supply like Motion Industries you can build your new one from schedule 80 steel pipe or and old truck axle shaft.
Take your new bushing and loose fit the new pin into it so that it lightly drags in the bushing. The notch for the lock is a quick simple torch cut.
Todd
01-10-2002 20:34:59
 Re: Re: Fordson Dexta Front Axle Pin in reply to Burrhead, 01-10-2002 17:41:34
Thanks for the info !
Burrhead
01-11-2002 16:13:09
 Re: Re: Re: Fordson Dexta Front Axle Pin in reply to Todd, 01-10-2002 20:34:59
You're welcome and I hope you have good luck with it.
