Oil bath breather
Walter
01-05-2002 09:50:56
I have a 1960 fordson power major and i was wondering if i need to chang the oil inside of the unit or does it have a filter down inside of it some where? Thanks
Lindsay
01-07-2002 21:27:06
 Re: oil bath breather in reply to Walter, 01-05-2002 09:50:56
I agree with John
You should change it every oil change. When you refill it must be refill`ed it to the fill mark EXACTLY. Any less means the filter doesnt work at 100% and any more and it will leak over.
john
01-05-2002 10:38:23
You should change oil in your air cleaner every time you change your engine oil, more often if you run in dusty cond. good luck
