Antifreeze
graytinker
01-01-2002 11:08:00
Drained the coolent out of the 1923 Fordson today. What I can remember when I Filled it this summer the book said it took 11 gal. I didn`t check the amount that I put in But I got only about 7 1/2 Gal. out. It was a little below the overflow pipe, witch I had to make when restoring the tractor witch I finished this summer. I guess the question is, should I be worried about water inside the Block? The antifreeze checked good for 0 degrees but some times it below that in northern PA..
