'63 FSM Grilles
Mark
12-22-2001 18:13:28
I am looking for a set of grilles w/headlight assemblies. My project is missing the left grille, and all of the lights have been ripped out for some reason!
I cannot for the life of me figure out how the headlights mounted...if there is any help I appreciate it!
Thanks,
Mark
Texas
Bob D UK
12-24-2001 12:51:37
 Re: '63 FSM Grilles in reply to Mark, 12-22-2001 18:13:28
The single mounting bolt at the base of the headlight goes onto one side of a fairly substantial 'U'-shaped piece of steel that bolts (x 2), lying on its side, onto the top of the front weight casting inside the cowl - the bolts also help to secure the front bottom of the cowl. The grilles have a lug at the bottom that fits to the bottom of the grille aperture in the cowl. The top is secured using a push-fit waisted stud that goes through a hole in the top of the cowl aperture - there is a spring clip fitted at the back of the hole to grip the waist in the stud. Hope this helps.
