Rear axle bearing leaking bad
walter
11-29-2001 05:03:30
Hi I have a 1960 fordson power major that leaks from the axle seal i called the New Holland dealer ship and they said that they have the seal i need to replace it.How hard it to replace the seal i have a IT manual but it says that i have to pull the hole axle out replace and retork the bull gear.My question is is the axle shaft solid or can i take off the tire and replace without having to take the axle completely out.Becouse im afraid i want get it retorked right and mess up the gears. thanks all.
Craig Wissink
12-08-2001 08:49:59
 Re: rear axle bearing leaking bad in reply to walter , 11-29-2001 05:03:30
Sorry, you have to take the whole axle out to replace the seal, just as the manual says.
