Fordson ID Help
JQ
11-18-2001 18:42:23
I'm asking for help in identifying the year of manufacture of a Fordson. I believe the serial # is F1338B (the B appears below the other characters) the number was on the head and may be a casting number.
Some other info: It's on steel all around. It has "Fordson" and "Detroit Michigan" on the rear of the fuel tank. It has no water pump. I've looked at pictures of an "F" and it looks very much like the Fs depicted.
I'm also curious as to the value. It appears to be nearly complete but non-operational. It has been stored in the Calif Desert and is not too badly rusted.
Thanx for your help.
ADAM
11-18-2001 20:29:36
 Re: Fordson ID Help in reply to JQ, 11-18-2001 18:42:23
The number you have is indeed a casting number. The tractor serial number is located between the first and second manifold runners stamped on the block. It is an American built "F" somtime after 1923, unless some one swapped a late fuel tank on to a early tractor. sounds like it could be a good project for someone.
JQ
11-19-2001 20:02:27
 Re: Re: Fordson ID Help in reply to ADAM, 11-18-2001 20:29:36
Looks like it's a '21 or '22. Thanx for your help.
JQ
11-19-2001 20:02:20
JQ
11-19-2001 20:02:09
