Re: Re: Re: Re: Front bucket Hydraulics
AL
11-02-2001 08:23:21
Thanks Bill, the old fittings on my front loader appear to be just low grade, standard cast fittings & pipe (different from the backhoe hi pressure fittings.) I priced the heavy duty fittings you mentioned and found that they were more expensive than steel, which were close to the standard ones. I did buy the swivels from Northern Tool.
I'm in northern NJ. There used to be a Ford dealer named "Caldwell Tractor" in Fairfield, NJ that WAS a good source. Too bad that they went out of business. I tried to track down where the parts went, but no luck. I was able to get adapter fittings through "Andover (NJ) Tractor" that allowed me to use cheaper standard hoses on the backhoe as compared to made up Fordson hoses.
