Re: Fuel problem
Mike M (RI)
10-26-2001 17:33:52
Jim...Been there, done that! Here's the fix. Turn the tank valve on...open the bleed screw on the outlet side of fuel filter & pump the lever on the glass fuel pump until no air bubbles appear at fuel filter outlet...close outlet bleed screw. Open bleed on injection pump and do the same pumping until all air bubbles are gone here also. Start tractor. If won't start, crack open the fuel line fittings at the injectors until all air is out, tighten...then she should start.
