Super Major pressure port
Shayne
09-27-2001 06:21:42
On the right hand side of my 1964 Super Major there is a pressure port used to check hydralic pressure relief valve. Does anybody know of any reason why I would not be able to tap into this for pressure to a hydralic remote?
thanks Shayne
Brian
09-28-2001 00:50:08
 Re: Super Major pressure port in reply to Shayne, 09-27-2001 06:21:42
Shayne,
This port is direct from the pump and a tapping on here would not be controlled. No pressure is available at this point unless the lift system is under load so the PRV would have to be open and be blowing off before you get a pressure rise at this point.
regards
Brian
