Simms injector
Tim
08-17-2001 22:32:06
Recently after running my fordson powermajor and having it cool down I noticed what apeared to be fuel coming from an overflow tube off of the injector pump,is this normal?related to preasure build up
Stephan
08-18-2001 09:32:56
 Re: simms injector in reply to Tim, 08-17-2001 22:32:06
Yes its normal, its the diesel that leaks
between the injection plungers. It lubricates the cam shaft and bearings so the overflow is a little above the shaft. It can increase when the plungers wear out (wich on a original pump is
allmost always the case)
Keep it running!
Regards
