Dexta Overheating
Bill G.
08-14-2001 15:48:56
Hello all
My 1963 Super Dexta is overheating shortly after I start it up and run it. It has the Perkins 3 cyl diesel engine. Beyond the obvious of exchanging the antifreeze/coolant, is there anything else I should look for?
Thanks.
Bill
texadian
08-15-2001 15:10:18
 Re: Dexta Overheating in reply to Bill G., 08-14-2001 15:48:56
I remember a customer's Dexta that that would overheat in a few minutes when loaded. It had a worn out waterpump impeller; we kidded him about using sandy water; maybe the Dexta has a tendency to cavitate at the waterpump. Leave the rad cap off and warm the engine up till the thermostat opens. A good waterpump should produce obvious flow in the top radiator tank.
It's sometimes hard to tell if an engine is overheating or if it has a compression leak from the cylinders into the waterjacket. Take the fan belt off and run it for a few minutes; if you see bubbles in the radiator top tank, it's bad news: head gasket, cracked head or cracked block.
ROD
08-15-2001 13:18:37
HERE IS A PARTIAL LIST OF THINGS THAT CAN MAKE YOUR TRACTOR RUN HOT:
BAD RADIATOR CAP
DIRTY RADIATOR
BAD THERMASTAT (WHICH SOUNDS LIKE YOUR PROBLEM)
LOOSE BELT OR SLICK OR WORN OUT BELT
INNER LINNING OF BOTTOM RADIATOR HOSE CALAPSE AND SUCKED TOGETHER
CRACKED HEAD OR BLOCK OR BAD HEAD GASKET
IMPELLER ON WATER PUMP SLIPPING ON SHAFT
HOPE THIS HELPS
WORN FINS ON IMPELLER
Bill G.
08-20-2001 05:04:22
 Re: Re: Dexta Overheating in reply to ROD, 08-15-2001 13:18:37
Thanks Rod. That is certianly a comprehensive list, and hopefully it will be one of the simple ones. I still haven't had a chance to work on it yet, but I will keep an eye out.
Bill
ROD
08-20-2001 06:57:05
 Re: Re: Re: Dexta Overheating in reply to Bill G., 08-20-2001 05:04:22
LET ME KNOW WHAT YOU FIND.
Jim
08-31-2001 18:37:29
 Re: Re: Re: Re: Dexta Overheating in reply to ROD, 08-20-2001 06:57:05
Try blowing out the rad from the rear. The Dextas rads have very narrow fins , much like a car , and get blocked very easily.
ferrell freeman
08-15-2001 09:36:21
You, should be able to get a thermostat from a NAPA store if there is one close. How does the coolant look you might also need to run some flush though the system ,also adding some cooling sysem conditioner to protect your cylinders .This will help keep holes from coming in liners.
Bill G.
08-20-2001 05:04:26
 Re: Re: Dexta Overheating in reply to ferrell freeman, 08-15-2001 09:36:21
Thanks for the suggestions Ferrel. I haven't had a chance to work on it yet, but I did look at the coolant, and it is pretty "thin" looking. I'll probably flush it as well, and look for the conditioner while I'm at the store.
Bill
Burrhead
08-14-2001 18:16:17
The Dexta is bad about getting dirty in the radiator air fins. All you have to do is blow it out with compressed air or wash the rad out from the back side towards the front. Just be sure not to use a powerwasher or the flues will shatter. The only other thing is the generater belt may be loose.
Bill G.
08-15-2001 04:22:56
 Re: Re: Dexta Overheating in reply to Burrhead, 08-14-2001 18:16:17
Thanks Burrhead. I looked over the radiator, and while I didn't find much in the way of dirt, it is easy enough to blow it out with some compressed air while I'm changing the coolant.
Bill
Oscar
08-15-2001 01:01:27
It's probably what Burrhead said, but it could also be the thermostat.
Oscar
http://fordson.freeweb.nl
Bill G.
08-15-2001 04:25:08
 Re: Re: Re: Dexta Overheating in reply to Oscar, 08-15-2001 01:01:27
Thanks Oscar. I'll keep an eye on that. After I change the fluid and blow it out, I'll just have to see if it keeps getting hot. If it does, that'll be the next thing to try. The closest Ford dealer is about 40 miles though, so I hope the thermostat is good for a while longer.
Bill
