FMD
Joakim
07-24-2001 12:30:06
I was wondering if anyone know how much hydralic power it should be on a FMD. I wonder this since i just put a frontloader on and it hardly moved, i measured the power and only got 40 BAR. My guess is that is way to low and that maybe my pump is out of order. Any sugestions on what could be wrong and how much preasure i should have would be most apreciated.
Joakim...
Brian
07-25-2001 00:05:21
 Re: FMD in reply to Joakim, 07-24-2001 12:30:06
Joakim,
Your pressure should be around 137 bar (2000 psi). When you try to lift do you here a click? If so it could be the pressure relief valve is set low.If not sounds like pump trouble as you say.
regards
Brian
Joakim
07-25-2001 04:52:24
 Re: Re: FMD in reply to Brian, 07-25-2001 00:05:21
I do hear a repeatably clicking sound coming from around the valve where the leaver is atatched (the one i use to raise and lower the rear lifters). It apears when I reach the top on my back lift and try to use my front lift lifting more than aprox. 50-60Kg. How do i raise the preasure if the pressure relief valve is set low?
