Thanks to help from this group, I found out I have a 'common' problem of seal between transmission and rear end leaking. It goes across pretty fast and must have been this way a long time as someone has installed a plumbing valve at the bottom right of pto I am assuming for draing oil to transfer back.Brian in this group has told me that for minimal use, I can continue to do this for a long time with no problems. I plan to mow some and at most maybe plow a 5 acre field this fall. Possibly drive it 7 miles to a friends house to mow too. My question is: Is there a level where I can hurt things? I am guessing before I use it hard or drive long distances down the road I should fill transmission up. I am also guessing that since hydraulics run off sump in bottom that a high level in the rear end won't hurt anything. Is the level in the transmission where it stops transferring over adequate for mowing around the yard for an hour or so in 1st gear or should I transfer oil before I use it each time? I am guessing that it is acceptable to use without transferring. Am I on the right track? I plan to split tractor this winter and fix it, but don't want to make anything worse before then. (I will be asking for tips on this when the time gets closer). On the brighter side of things. It runs great and works well, loving every minute of it. I thoroughly enjoy the diesel smell coming off it. Running out of jobs to do with it..... .Might actually have to get to the jobs the wife wants done! I live in SW Wisconsin and we have gone 23 days without measureable rain, keeping the grass from growing. I used to hate mowing. By the way, what is the seal like that is leaking? Is it a round shaft seal around the shaft going back to pto/hydraulic pump that is leaking?
Thanks in advance.
Bruce
