Fordson Power Major in Australia
Miles Hazel
07-04-2001 07:03:00
What do I have ?
I have just purchased a Power Major - but not sure exactly what I have !! I has the identification on the right hand side of the block... Ford FL - then below the injectors EIADKN 6015 E. It has Power Major Badges but not sure if the engine is of the same. I would also need to purchase a headlamp lens - getting to Los Angeles or London would not pose a problem.
Many thanks Miles.
Steven B
07-04-2001 15:56:35
 Re: Fordson Power Major in Australia in reply to Miles Hazel, 07-04-2001 07:03:00
FL on the cylinder head indicates late Super Major. It probaly has a later engine. There is a build plate with a date on it on the fire wall near the back of the rocker cover. This will have the Aust build date. The other number is the part number for the block. Parts are readily available in Australia. You can get your headlights from a New Holland dealer.
