Ether
wesley scheltie
06-22-2001 09:44:04
Hi
I know, i've got always questions...but i'm just a kid (17 years, belgium, bonheiden). But I hope I can do something for you in the nearly future too. I found the original manual of a fordson dexta, you see. With pictures and all in it.
My question now, i'm always starting my dexta's with ether. But I've heard it is very badly for the engine. But one of them doesn't want to start anymore without it, it looks he is "used" to it. Strange...
Is it indeed worse for the engine to use ether by starting ? And if it is, what to do about it ?
Thank you, Wesley
Pete Tatham
06-23-2001 04:01:29
 Re: Ether in reply to wesley scheltiens, 06-22-2001 09:44:04
If an engine wont start without ether it's usually a sign of low compression which the ether makes up for. Are there any other signs of worn cylinders such as blue oily exhaust smoke? You might get away with just installing new rings, but if the compression's well down then a full engine rebuild will be needed, not a big job on a Dexta.
Pete.
