Fordson F Judder
john
06-18-2001 12:05:56
Hi,finally got my F running. only one problem now the engine judders at fast tick over. It is fine if I slow it down or speed it up but I cant get past this particular spot on the revs without this juddering. It is firing on all cylinders OK even when juddering. Any ideas anyone?
Thanks, John, Yorkshire
Theman
06-22-2001 13:33:47
 Re: Fordson F Judder in reply to john, 06-18-2001 12:05:56
My guess is that something has flown off of your flywheel. There are V-shaped magnets attached to the flywheel that provide electricity for the ignition coils. One of these may have broken. Unfortunately, the only way that I know to check this for sure is to split the tractor and remove the flywheel. If you remove any magnets, be absolutely sure to have their polarity correct when you put them back on. A compass is a handy instrument for this.
You didn't say how many revs it is turning but around 1000 rpm is all I feel safe with around my Fordson F. Still, it should not shake as you have described.
