Re: Re: Re: Re: Fordson Dexta Rear Axle Oil Leak
Burrhead
05-31-2001 12:28:00
Trying one more time. I could'nt get the pix to blow up.
David
06-06-2001 21:30:19
 Re: Re: Re: Re: Re: Fordson Dexta Rear Axle Oil Leak in reply to Burrhead, 05-31-2001 12:28:00
Burrhead,
Thank you for the insights. Will let you know how it all goes ... may take a couple of months as the tractor and I are separated by 250km (150 mile)
Para 75A seems to be the core of the procedure.
Thank you again
David
David Gates
09-16-2001 20:54:09
 Re: Re: Re: Re: Re: Re: Fordson Dexta Rear Axle Oil Leak in reply to David, 06-06-2001 21:30:19
Just a short note to say the job to replace the oil seals and bearings on our Dexta is done and all looks OK after a few days work. (4
Hectares slashed, several rolls of hay put out etc)
My one addition to the standard oil seal/bearing replacement was to use a "speedie-sleeve" on the axle where the inner oil seals run.
These are stainless steel sleeves designed to press fit onto a shaft and provide anew surface for the seal. (the Speedie sleeve I used is
numbered CR99212 -for the 2.125 inch shaft, approx 1 inch long, it covered the 0.007 inch groove worn by the old seal)
If anyone wishes to buy bearings, the cone (The bit that goes on the shaft with the rollers in it) is numbered 387 and the cup (the outer bit
that goes in the hub) is 382. These are recognised by the bearing companies and the parts are sold separately.
In Aus the retaining rings were readily available at $Aus80 each, as were the inner oil seals. The outer seals, like the bearings are
standard items that could be brought from a bearing shop!
Getting the bearing off the axle (after removing the ring using a 3/8" hole drilled all the way through ... carefully avoiding the shaft)
required more push than I had. A friend of a friend helped out with a 30ton press that made short work of the obstruction to progress
(about 10 ton was needed to shift the cone on one side, the other about a ton).
Appropriate amounts of heat as suggested by Limpan earlier in this thread made reassembly a treat.
I did have to remove 1 x 0.020" shim to get the axle freeplay to within the 0.004-0.012" tolerance specified ... hope that was just wear
rather than me making a blue!
Thank you all for your help with information to allow the job to proceed.
regards David
Oscar
06-01-2001 11:16:19
Burrhead, could you email me a full-size version of this image you posted? I could use it!
Burrhead
06-01-2001 20:37:24
 Re: Re: Re: Re: Re: Re: Fordson Dexta Rear Axle Oil Leak in reply to Oscar, 06-01-2001 11:16:19
It's on the way Oscar. Let me know if it came through ok.
