Dexta Hydraulics
JD
05-07-2001 16:30:51
My Dexta with selectable (on or off) Qualitrol hydraulics will not lift the 3 point linkage higher than approx half way, I have checked oil levels etc so I suspect it is something to do with the internal settings can anyone help?
Thanks
Burrhead
05-07-2001 19:28:33
 Re: Dexta Hydraulics in reply to JD, 05-07-2001 16:30:51
JD there is a spring loaded rod attached to the lift lever under the top cover that usually has come out of tension when that happens. Most times you can just let the lever back down and pull it back up and the linkage will catch and go ahead and lift.
If you take off the top cover. When you turn the cover over you will see a long threaded rod running through a spring connected to your hand lever. Tighten the nut down on the rod until you can barely turn the spring with your thumb and 2 fingers.
I can't find my trifocals right now but I think it's item 23 on the attached diagram.
JD
05-11-2001 06:46:48
 Re: Re: Dexta Hydraulics in reply to Burrhead, 05-07-2001 19:28:33
Thanks, much appreciated.
