Governor. Vaccuum Pipes
Xris IOW
05-03-2001 14:11:19
My FPM Has got two very rusty and holey inlet manifold to governor pipes that I have currently taped up to keep the atmosphere out. Thier route to the governor goes via the gap between the rocker cover and the radiator hose. So far so good.
I have obtained from "Pococks" UK two new/fresh ones that unfortunately come from a tractor that had them routed below the thermostat housing. My cylinder block has a nasty square corner on the cylinder block just where they need to pass.
Looking at various fordson pictures of this area I see that either route was taken. Therefore before I cut off the square projection could some kind soul enlighten me as to the reasoning behind this and whether I'm heading for a mine field or not.
Many thanks and apologies for the long message
Xris
Brian
05-04-2001 03:46:45
 Re: Governor. Vaccuum Pipes in reply to Xris IOW, 05-03-2001 14:11:19
Xris,
The later Power, Super Majors with vacuum governors had the pipes between the rocker cover and thermostat housing. I have often fitted the later ones to the older tractor but never the other way round. What is important is the pipe size. Later tractors had one large and one small to reduce governor fluctuation.
regards
Brian
