Fordson Power Major Hydraulic lift powerless
Shane
04-18-2001 18:45:29
I have a FPM with a hydraulic lift problem. The tractor is fitted with a front end loader. The problem is that when the bucket is loaded up the lift doesn't operate. It has been fine in the past. The other problem is the 3 point linkage has always fallen unless you raise it up to the top and a clicking sound is heard and the linkage stays raised unless you lower it. If you don't hear that clicking sound, the linkage falls slowly. Ever since the problem with the FEL I cannot get that "klick" to keep the linkage up. Firstly is this the way the linkage normally operates (ie. do you always have to raise it right up to have it hold) and what could be wrong with the FEL? Any answers will be greatly appreciated.
Thanks!
