Re: not getting a lift out of life.
Brian
03-24-2001 09:32:20
Nelson,
The linkage was never designed to hold up when the engine and lift pump was not running.
If they drop quickly when the clutch is pressed or the engine stopped then you have a leak on the piston seal.
If you put the selector lever in the up position and the control lever in the raise position, when hot, with an implement on the linkage in the raised position, engine running, you should see the lift correct (jump) eight to ten times in a minute. Any faster than this and you may have a piston seal that is worn.
If the lift drops over a couple of hours or overnight this is normal.
regards
Brian
