Super Dexta 3point lift problem
TOM FORREST
02-20-2001 11:47:04
lift has a bumpty bump to it worse at full up also tends to go down perty fast after shut off.
It has 30 wt oil is this not correct? also need kit to rebuild cold start fuel primmer valve.
note: everone is right!! do not use starting fluid
I am replacing pistons for this stupid mistake.
Burrhead
02-26-2001 17:20:15
 Re: Super Dexta 3point lift problem in reply to TOM FORREST, 02-20-2001 11:47:04
90W is the correct lift oil.
Don't worry about the quick leak down after you shut the tractor off.
I'm not sure what you mean on the bumpity bump, but when the lift is all the way up the unloading valve will start to engage-disengage to keep the pressure from blowing the piston ring so that could be it, or you could have a gummed up unloading valve that is just jumping in and out on the pressure release causing it to bumpity bump the lift.
I'm sorry to hear of how you learned your ether lessen, but on the bright side of the problem you probly won't ever do that again.
TOM FORREST
03-02-2001 10:45:24
 Re: Re: Super Dexta 3point lift problem in reply to Burrhead, 02-26-2001 17:20:15
BURRHEAD THANKS FOR THE INFO IT SHAKES OR BUMPS AT ANY AMOUNT OF LIFT. AGAIN IT HAS 30W OIL
JUST WHERE IS THE UNLOADING VALVE AND HOW DO YOU FIX IT.
BY THE WAY A OLD HIGHSCHOOL FRIEND OF MINE HAD THE NICK NAME BURRHEAD
TOM
