How Fast Should FMD Engine Turn To Startup?
TMAC
02-01-2001 16:17:32
I have bled the system with fuel coming out at the injectors. I checked the timing and its on the money. Still won't start up. The engine cranks over slowly with a new 950 CCA battery. Does it have to crank fast to start? This tractor has sat for 7 years. Could I pull start it? I also need to know what position the high/low shifter is for low and high.
Brian
02-04-2001 03:20:48
 Re: How Fast Should FMD Engine Turn To Startup? in reply to TMAC, 02-01-2001 16:17:32
TMAC
Low up, High Down. Standard Tractor.
High up, Low Down. Tractor with Live pto.
regards
Brian
