Re: Re: Fordson Super Major, Hydraulic Trouble
Huub
11-21-2000 13:13:19
Leon, what was your first problem? Maybe you have forgotten to mount an O-ring or maybe damaged one when re-assembling (pipe from pump to hpl?).
Geo, if you use API GL5 (hypoid oils), the bronze parts in the transmission rear end may be affected by the additives in the oil. Also the nitril rubber seals (pto-shaft) might become harder in a shorter time so you might get leakage after a period of time. Gear oil API GL4 is ok.
