Re: Re: Re: Re: 1923 Fordson F
FordsonExchange
10-02-2000 14:40:45
Your Fordson may have a factory built replacement engine. This may account for the absence of serial numbers.In some instances they may just be worn off. Check out the opposite side of the engine. That section that would ordinarilly be covered by the Coil box. If there is no coil box look in between the coil box mounting studs. If you find the Ford Logo casted in coupled with a smooth block where the serial numbers should be,it is probably a replacement engine. Don't give up yet. The dash board is another source to check the approx year, that is if it is the original dash. A dash with casting marks in the patented area is probably that year or possibly one year newer. Re left over pieces used in the next production year. If all fails get back with me. If you don't mind getting messy, I can direct you to another location. For now, don't concern yourself with the actual year. Get the engine free and work on getting it started. We both live in Ma and I always ready to help out a fellow Fordson enthusiast.
Raymond Smart
08-23-2005 14:27:46
 Re: Re: Re: Re: Re: 1923 Fordson F in reply to FordsonExchange, 10-02-2000 14:40:45
I have a similar problem in identifing the serial number, I was wondering what this other messy method of finding out what the year is?
Owen in Mass
10-03-2000 06:32:23
Thanks for the info. Its going to be a while untill I will be able to get it started. i am going to have to re-build the engine before it will run. I also need the ignition system, and the fuel system, I will need a manifold, the one I have is in really sorry shape. I suppose it will do if I can not find anything else. It also has a couple of stuck valves. Can I use a model T engine re-build kit? I have the Snyders catalog. I know it has bigger pistons, but the valves and overall dimensions of the engine appear to be the same. Check out the website, you can see the very detailed pictures of the Fordson.
Don(CO)
10-04-2000 08:15:55
 Re: Re: Re: Re: Re: Re: 1923 Fordson F in reply to Owen in Mass, 10-03-2000 06:32:23
Owen.. about the only interchangeable parts with the Model T and the Model F tractor are ignition system including the timer, magneto horn on industrial models, and the air breather cap on the steering box housing. The Model F engine, although engineered very similar to the model T engine... is much larger, longer, with greater cylinder displacement. Model T parts will be of no value to you.
Dan Zilm, in Minnesota; has the babbit jigs necessary to pour new babbitt bearings and to line bore the block. ADAM ... who is an accomplished Fordson engine person on this forum, may be able to offer some guidance on engine overhaul.
ADAM
10-12-2000 20:17:02
 Re: Re: Re: Re: Re: Re: Re: 1923 Fordson F in reply to Don(CO), 10-04-2000 08:15:55
Most "T" parts air not interchangeable with the Fordson there are plenty of handy hardware items such as, coil box leads and hardware, correct nuts and bolts, fuel valve/bowl assys, correct fuel line packings, rebuilt coils, coil parts, coil box lids, wire harness and other misc. items. It is nice to be able to get some new parts to repair fordsons. I often wish that I could walk into my local ford dealer and order parts like the John Deere guys can do.
Owen IN Mass
10-03-2000 06:35:13
The URL did not come thru!!
Link
