Dexta shifter (stuck in reverse)
ger
09-29-2000 13:36:34
Does someone know what the dimensions of the bottom square section of the shiftlever should be, before it wore out and started stranding me in reverse at inconvenient times?
Thanks in advance.
Burrhead
09-29-2000 14:17:07
 Re: Dexta shifter (stuck in reverse) in reply to ger, 09-29-2000 13:36:34
5/16" X 7'16" but the corners have to be rounded and not square or it won't switch shift rails.
Be sure to check the lever's pivot pin and spring for tension. If the spring is loose or the pivot pin worn out it will still hang up even with a new shift lever in it.
ger
10-03-2000 13:06:53
 Re: Re: Dexta shifter (stuck in reverse) in reply to Burrhead, 09-29-2000 14:17:07
Thanks! Does the long dimension (7/16')run front to rear of the tractor?
Thanks Ger
Burrhead
10-03-2000 15:38:58
 Re: Re: Re: Dexta shifter (stuck in reverse) in reply to ger, 10-03-2000 13:06:53
Yep 10-4, the 7/16" is front to rear.
