Hi Jack The reason you have to do the extra jiggle is this. At the far end of the linkage under the differential cover there is a spring and an adjustment nut on the linkage rod end. Over time and through normal wear the spring either becomes weak or the end of the linkage wears down and lets the linkage slip when it should be pushing the internal valve control. On my Super Dexta I sometimes have to let the 3 point control back about 2" then take it back to the top for 2-3 times before it will completely load the valve. If you don't mind the agravation there is nothing that this will hurt. You have to take the differential top off and adjust the linkage, and it's not too hard to do, but it's easier for me to run mine like it is. If you decide to fix yours I will get the books out and tell you the torques and length of the linkage when you need to know. I like to help someone like you who is excited and energetic to get it working right. There are too many people who ask for info and never even try to work on their tractor, they just take it to a shop anyways. I would email you a copy of the book but it has gotten old and yellow. When you try to scan or photocopy it the pages all look black or dark brown and you can't see anything.
