Hello everyone,Yesterday evening I decided to troubleshoot my tractor's hydraulics. Tractor is the Fordson ASP (All Spare Parts) which uses hydralics of a '55 FPM. They lift OK but the revs need to be high, and they leak down very rapidly.
I removed the hydraulic control valve assembly, which took much levering and pulling until I removed the top and bottom bolts as well, after which it came off really easily!
After reading several similar posts about hydraulics leaking down quickly, I was expecting to find a problem with the main piston cylinder or seal. In fact the seal looks just like the new one that I have, and although the cylinder does have a couple of scratches, there's nothing I could honestly call deep scoring.
While cleaning the cylinder up however I did notice that there is a lot of black, gunky sludge in and around the control assembly, that I can only describe as, well, black, gunky sludge.
I guess I have to take the valves out and clean them up, yes?
The manual shows very complicated assemblies with springs, little balls and so on - the kind of things that are good at loosing themselves...
Sooo.... is there anything special that I should know before taking the valves out? Anything particular that I should be looking out for, or be careful of while doing this job? Can I re-use the piston seal? It really looks fine.
Also, is it possible that the problem is in the valve attached to the operating handle? I kind of have my suspicions about this as it's leaking oil from there (but then again, it's leaking oil from just about everywhere...)
Many thanks,
John-Paul
