59 Dexta Diesel,Priming Problems
George McNamara
08-16-2000 16:30:31
Have Dexta diesel, changed fuel filter, no fuel pump primer on fuel injector pump. Have fuel running out of both bleeder screws on filter and tractor will start. When runs does so with a surging idling speed only. Ran well before changing filter. What do I need to do next?
Thanks for any help, George
George
09-05-2000 20:11:44
 Re: 59 Dexta Diesel,Priming Problems in reply to George McNamara, 08-16-2000 16:30:31
Thanks Burrhead for the info. Everything is running fine now. Sorry to take so long to get back.
Burrhead
08-16-2000 20:53:50
George just above the engine stop lever on the side of the injector pump there are 2 of the 1/2" headed bleeder plugs.
Loosen these 2 plugs with the engine stopped, and let the air out of the pump. Gravity from the fuel tank will bleed the pump, that's why it does'nt have a primer pump.
If you try to run it without bleeding the pump it may purge the air without bleeding it, or it can lose it's prime all together and go dead.
If it loses it's prime you'll have to bleed it at these plugs anyways so it's easier for me to bleed it there 1st.
Good luck-Burr
