Re: Re: super major resurrection
peter wilson
06-03-2000 04:17:17
Brian:
Not yet. Had a site visit from Steven B who lives 10 km away. He got his shoes dirty on the black clay!
Just got a fuel filter as the old one was suspended from its pipes.
However, as the steering box had been taken off and the carcase was in unprotected storage, the gearbox appeared full of viscous cafe-au-lait. I suspected rain had helped raise the level, and when I drained the gearbox, the coffee drained out, with some water. With the belt pulley cover off and the bottom plate held by 6 bolts off (which also drained some of the rear axle - more oil needed), the gears seem remarkably good, and I can statically select all 8. I will fill with oil and see what happens. I do have a spare rear end.
Back to the fuel: I will clean and assemble the tank, and fit once the steering bax is back on. Steven suggested a view of each injector pumping, and if one does not, minor disassenbly and boiling in diesel. I suspect it will be a full days work to get everything back together, and just in case it does start, I need to disconnect the crankshaft mounted pump as I think the reservoir is dry. I now know why farmers have large oil drums lying around!
Will advise how the start (or not) goes,
Peter.
