Re: Re: 55' Major Deisel
Matt
05-25-2000 12:14:39
Brian-
thank you for the information. How many quarts/liters do I need for engine oil and also for axel/hydraulics?
Helton
05-25-2000 23:31:33
 Re: Re: Re: 55' Major Deisel in reply to Matt, 05-25-2000 12:14:39
For the 90wt. is anyone familiar with a mineral oil for gear drives? My best parts guy recommend it highly & it doesn't smell& works well in the aux. cylinder,cheaper too- Gearbox=4.5 Imp. gallons with pto 4.25 without Rear=9 imp. gallons convert Brit. to American x1.2 if(if not mistaken)MAJOR IMPROVEMENT IN OIL TO ME GOOD LUCK Helton
Brian
05-27-2000 12:24:18
 Re: Re: Re: Re: 55' Major Deisel in reply to Helton, 05-25-2000 23:31:33
Helton,
The one thing that can ruin a hydraulic pump or motor is air. Some oils cavitate ie. when pumped they froth and trap air in the oil. As long as your oil does not froth and contains additives to lubricate the gears under load when the teeth engage, then it is fine. Word of warning. If you are recomended to use an oil, ask if they will put the facts in writing. Most oil companies will do this. I had a case where the Shell rep. advised a farmer to use a certain oil in a system which contained hydraulic motors. Within a week every pump and motor failed on the machine and Shell replaced the lot FOC because the rep had given a written recomendation.
Most tractor handbooks will give an oil spec. As long as your intended oil meets or surparses that spec all is OK.
regards
Brian.
