Re: Stuck Screw On Brake Drum
Ed Burress
07-01-1999 06:22:25
Hi Joe,
I usually have luck by heating with a torch, allowing it to cool some, and spraying with WD-40, or a good cutting oil. Allow it to soak, and try again. If that fails, I have used a rotary impact hammer with a screwdriver tip in it. The shocks from the rotary hammer tend to loosen the screw/bolt better than a constant force. You can buy a tool that you can attach sockets to, it has a lever that causes the socket to go the the left or right (loosen or tighten, just like a socket wrench). It's kind of like a socket wrench that you hit. Anyway, I have some old sockets with screwdriver tips welded into them. I place one in the slot, give it a few hits with the hammer, and the screw or bolt usually turn just a little. That's usually all that's needed, just a little nudge. If all else fails, drill it and use an ease-out, or drill it larger and re-tap.
Good luck,
Ed
