Production date
Robin
04-23-2000 12:19:00
Can any of you guys give me a production date for a petrol/TVO Fordson E27N? The only number I can find on it is E27N 6093 on the left side of the engine block. If this is just a casting number where else should I look? I don't know much about these big beasts I usually play with Ferguson T20's but I'm helping a friend out getting the Fordson running.
Thanks in advance. Robin
Nathan
04-23-2000 16:19:31
 Re: Production date in reply to Robin , 04-23-2000 12:19:00
The number you found is a casting #. The serial number should be located on the upper, right hand side of the block. On the surface where the manifold bolts up, between the front two ports. It should be a six or seven digit number. You may have to scrape around a little as it may be covered by rust or the manifold gasket. If you find the number, I can give you the production year.
