Oil level for hydraulics/axles for 62' Dexta
Tom
04-18-2000 20:41:36
How do I tell if the oil level is corect in the rear of the tractor?
Burrhead
04-19-2000 16:21:16
 Re: oil level for hydraulics/axles for 62' Dexta in reply to Tom, 04-18-2000 20:41:36
The check plug is the one there by the pto shift lever. Take the plug out and then add til oil runs out the plug hole. You add oil through the big plug up top of the rearend housing behind the right side of the seat.
The tranny checks at the plug over the right running board just behind and below the left brake pedal in the tranny housing. Same deal with it, take the plug out and add oil through the top plug in the tranny til it runs out the lower plug hole.
