Re: Valves for Fordson N 1938
ken
04-17-2000 20:32:22
I had another thought on the valve question that I answered recently....as I thought about the size a little more, I think that the valve stem is 1/32 larger on the late model Fordsons instead of 1/16. I was only able to purchase the smaller stem size and guide. When I installed the guide, I polished it in a drill press first, then put some stud locker on the outside to make sure it stays in place. There will probably be a flange on the old guide which is not on the new one. I made a flange out of a large washer so that my spring would have about the same compression as it originally had. You will also have to set the clearance to the lifter by grinding the valve stem off or possibly grinding a new seat in the engine to get the correct clearance. Hope this helps.
