Re: Re: Re: The Plan...
Brian
04-06-2000 05:18:47
John-Paul,
This is a poor excuse. You could have at least tried one that involved frost bite whilst checking the clutch clearance:)
Your oil could have been drained for some reason. The only place on the machine that would affect both gearbox oil and rear axle oil is if someone has had the pto shaft out and removed the housing at the bottom of the gearbox. Or a major oil loss from the rear end may be something to do with the external hydraulics. You will certainly need oil in the back axle when you start or make certain that the pto is disengaged as running the hydraulic pump dry could prove fatal (for the pump and your bank balance).
Best of luck.
Brian.
John-Paul
04-07-2000 00:09:51
 Re: Re: Re: Re: The Plan... in reply to Brian, 04-06-2000 05:18:47
Hi again
Just briefly... 1. How do I make sure the pto is disengaged? Handle forwards or backwards?
2. Is there any possibility at all that the vehicle could have a negative earth? I ask because the battery leads have the correct size terminals for negative earth (is the earth slightly fatter?), anyway the battery fits this way round, also the previous owner says that it is so, and that his Super Major also has the negative going to the chassis, also this is how we started it up! Having said that, my first ever job was driving an ERF 16 tonner that had a five-cylinder Gardner diesel in it which would run backwards after a fashion if you happened to stop cranking it at just the wrong moment. Entertaining to discover that you had ten reverse gears, and alarming to think about just how effective the oil pump was running backwards...
Cheers everyone and have a good weekend
J-P
PS Brian, as you're a Brit, did you ever notice any anachronistic ERF 'A' series wagons on the road during the mid 80's?
Brian
04-07-2000 10:07:32
 Re: Re: Re: Re: Re: The Plan... in reply to John-Paul, 04-07-2000 00:09:51
John-Paul,
Handle forward is pto disengaged. All Majors were positive earth. Fords did not go to negative earth until 1965. The "fat" terminal is positive. You will be ok whilst the dynamo is disconnected but all your good work could disappear in smoke if the dynamo is connected the wrong way round.
regards
Brian.
My brother drove ERF's with the Rolls - Royce diesel with air shift in the late 80s. Eight wheelers, Some machine. My memories is of the 1960's when a local coal merchant had a Foden with a horizontally opposed two-stroke, similar to a Commer TS3. Again an eight wheeler and with a full load of coal, when it pulled up a short hill away from the traffic lights in our town, the windows of our car showroom 50 yards away used to vibrate.
