Fordson F Mixer
Jason O'Brien
03-31-2000 19:17:45
I'm looking for a fuel mixer for the Holley 234 manifold, and a Holley Vaporizer for a 234 or 280 Manifold. The parts are for my 1922 Industrial Fordson thanks, Jason
Fordson Exchange
04-01-2000 13:37:49
 Re: Fordson F Mixer in reply to Jason O'Brien , 03-31-2000 19:17:45
Jason, The pieces you are looking for are getting more difficult to find. I just finished a 23F using the same mixer & carb you need. There are some available at top dollar. If you are not in a hurry, don't spend the big bucks. Attend as many tractor shows with flea markets as possible. Try to arrive as early as day break or the night before. I've had some good luck at car shows too. If You're going original you'll need the S676 b or c vapor tube. I found a machinist that makes them for gas only. I may have an extra air washer tube if you need it. Did you see my item on the replacement air washer filter? Good luck. RLL
