High Temp Manifold Paint Needed
RLL
03-30-2000 21:15:51
Once had access to super high temp black paint for use on exhaust manifold with a range of 1800 degrees. Product is no longer avail re lacquer base. Is there a good high temp paint available? Would also be interested in high temp enamel paint for same application.
Theman
03-31-2000 07:44:46
 Re: High Temp Manifold Paint Needed in reply to RLL, 03-30-2000 21:15:51
The only high-temp paint I've run across is sold by the Eastwood Company but I think they only rate their paint to 1200 degrees F. Are you sure you want anything to get to 1800F? We anneal steel tubing here at the plant at 1700 degrees and it's a dull red when it goes through. I've added a link to go to Eastwood's page. I believe it to be in the 'Specialty Coatings' section. Good luck. Let us know if you find something.
