Crankshaft
shoestring
03-27-2000 16:22:42
hello got a dextra and the crankshaft will turn but the flywheel i can't get to turn -what 2 do next --thanks shoestring
Steven B
03-27-2000 20:39:52
 Re: crankshaft in reply to shoestring, 03-27-2000 16:22:42
Sounds like the crank has broken or the fly wheel bolts sheard. The first is the most likly. probably at the rear main journal. Pull of the sump and have a look.
Sorry to bring bad news
Steven B
steven b
03-28-2000 17:03:26
 Re: Re: crankshaft in reply to Steven B, 03-27-2000 20:39:52
steven b thanks 4 the reply on the crankshaft, i was in hope;s that it was not the shaft broke an i was out today looking an i think i found out what it is, we were turning the back of the pulley it was just going round & round. this thing has been setup 4- 6, years. could u tell me if on the front of the crank does it have a shear pin in it, i have found a shop manuel on it but it does not list that.if it is the crank i'm not out but $50.00 dollars, i think it is still not unstuck
thanks again steve
Oscar
03-27-2000 22:16:33
The crankshaft is likely to be broken. You can have it replaced, but it's a pretty big repair and it's going to cost you some. An alternative would be to find another engine somewhere and just swap engine blocks.
Good luck!
