Fordson Power Major 58
generator electrical
John
03-11-2000 13:57:01
Some months ago I purchased what I believe to be 1958 power major. Everything seems to match what should be on the power major (I have not found or looked seriously for the serial#). My current project for this tractor is its electrical system. The previous owner indicated that he just charged the battery after he was done with the tractor for the day and had done this for 10 years or so. I'd like to fix/replace the generator and electrical wiring since there is not much left to it (its all cracking). The generator on the tractor has the
following info:
LUCAS
22259K 12 61
C39P2 L1 0 12v
Any chance of finding a similar generator? Or
recomendations for a replacement electrical system (generator and regulator)?
Also looking for the Clip for the throttle linkage. I believe its is part # C5NE-9A792-A
Suggestions anyone?
Thanks,
John
Brian
03-12-2000 02:37:40
 Re: Fordson Power Major 58 - generator electrical in reply to John, 03-11-2000 13:57:01
John,
Your dynamo is December 1961 so must have been replaced or tractor date is incorrect. All these parts are freely available from Lucas depots here in England so should be no problem. The dynamo front plate has now been modified to fit tractors with both right and left hand mounting, just by removing the main through bolts and turn the front plate.
regards
Brian
