William: Unfortunately, I am not aware of a comprehensive interchange source. You most likely have the I&T Shop Manual. There will be some reference in that manual as to interchangeability but not inclusive. The most comprehensive source would be an original Fordson Major Service Manual, complete with Service Bulletin addendums. (They are out there... but hard to come by). Your first step should be to identify your engines as Mark I, II, III, or IV series, copy down your engine serial numbers side by side and then when you read and re-read your I&T manual in the diesel engine section, make detailed notes or highlight the paragraphs in the manual that discuss FMD FPM FSM similarities or differences. I believe Intertec refers to differences mostly by before and after a specified serial number. An original service manual will refer to parts interchangeability by both Mark series and engine serial number... drop by every old Ford/New Holland and New Holland dealership you ever drive by and ask if they have a an original Fordson service manual packed away in the back or boxed up and stashed in the attic. You may come across one. If the service manager has been in the business for 40 years or so,,, their face will generally light up, if not; you generally get blank stares, shrugs and mutterings of "Is this guy out of his mind?" I stumbled across a dealership in Iowa while passing through one time and the close to retiring service manager literally broke down when I came in inquiring about information dealing with Fordson tractors. We maintained a close friendship for several years and intermittantly I received in the mail a page or two or three of old service bulletins he came across. I think before he retired and hence passed on he went through every old box, file, and stack of papers in that entire dealership to find and send each and every morsel of Fordson information he could find. Mark I engines: to serial number 1425096 Mark II engines: from 142096 to 1591023 Mark III engines: from 1591023 and up *These numbers are as accurate as I have been able to research and discern from Fordson records.
