Dexta
Removing Crankshaft pulley /start Jaw.
JohnG (M0)
03-04-2000 19:44:24
I need to replace the front engine seal on my '61
Dexta. I have pulled of the front end without any problems.. Now the manual says remove start jaw and crankcase pulley. I havent a clue how to remove these parts. Anybody had any experience with this?
Thanks
John
Brian
03-05-2000 01:57:52
 Re: Dexta - Removing Crankshaft pulley /start Jaw. in reply to JohnG (M0), 03-04-2000 19:44:24
John,
Start Jaw is the big nut in the centre of the crankshaft pulley. Jam the engine and unscrew. You can tap it with a soft drift to start it and there may be a tab washer to release.
To draw the pulley you may have to make or borrow puller. You could also CAREFULLY tap the pulley off useing a soft drift on the pulley hub. NOT the flange and turning the engine to stike in a different place after a couple of strikes.
Be careful. Remember a hammer can be a divining device to find expensive or hard to find parts:)
regards
Brian
