Fordson Tractors Discussion Forum
61 Dexta Diesel Oil Pressure
Stephengee
04-03-2008 19:18:30
What is a somewhat normal oil pressure, realizing
that age and type of oil varies. Is the oil pump accessable without complete teardown..Just found this site, Fordsons are a bit rare, Is there a diesel oil additive(STP)
David allen
04-11-2008 04:27:11
 Re: 61 Dexta Diesel Oil Pressure in reply to Stephengee, 04-03-2008 19:18:30
Please do not use STP! STP cakes on surfaces and then brakes loose and clogges drain holes and any other hole it can find. I have used very few oil additaves knowing if engine is working properly no additave is needed but I have used LUCAS with much sucess on worn leaky engines that customers do not want to spend money on.
DAO
04-04-2008 14:00:35
I USED ALOT OF DIFFERENT BRANDS OF OIL IN MY 63 SM . OF THE 15W-40 THAT I USED I SAW THAT ROTELLA IMPROVED MY OIL PRESSURE QUITE A BIT. THAT WAS BEFORE I DID A REBUILD.NOW IT STAYS AROUND 40 LBS.
kenneth armour
04-04-2008 10:23:23
40 psi I think.
That is what it is for my 64 Super
STP My mechanic hates it, Just gums up the engine.
Kenneth
