Fordson Tractors Discussion Forum
Re: Horsepower
Bruce Hopf
03-30-2008 22:23:44
That could be engine oil. The rear engine oil seals I found are notorious for leaking. I have a 1962 Dexta, not the Super, and it leaks. Some day I will have to split the tractor, and replace it. Hope this helps. The draft control, is to help pull the plow in, if it goes up on its own, when you pull the lever up, and when you push it down, it lifts the plow up a little if it sucks in too deep. Great little tractor. Around 38 to 40 Horse Power.
