Fordson Tractors Discussion Forum
Fordson Dexta Timing Gear Cover
Frank H erd
03-26-2008 14:20:06
Anyone know where I can find a timing gear cover for my Dexta. It's a '58 Fordson Dexta (not the Super); British built Continental gas engine. Thanks
cdmn
03-27-2008 19:24:36
 Re: Fordson Dexta Timing Gear Cover in reply to Frank H erd, 03-26-2008 14:20:06
Ask for part No B7086. Your aftermarket tractor parts dealer should be able to order it. If you're in there, I'd recommend that you get B1843, a new governor set. They are quite delicate. In my tractor, this failed and jammed the timing chain and bashed up the cover. I got the chain and gasket and seal at the Agco dealer.
woodache
03-26-2008 17:32:25
 That is a Re: Fordson Dexta Timing Gear Cover in reply to Frank H erd, 03-26-2008 14:20:06
That is a Standard engine not Continental, Check with a MF dealer or 35 in the junk yard.
