Fordson Tractors Discussion Forum
FORDSON MAJOR PARTS
dromonedog
01-27-2008 15:42:58
Restoring a new major ,a power major and a super major and in need of several parts ie brake shoes springs cables, front axle bushings bearings seals, gauges, air intake hoses and rad hoese,water pump oil pump, tach cable and the list goes on. DOES ANYONE KNOW WHERE I CAN SOURCE THESE PARTS WITHOUT HAVING TO SHIP FROM THE U.K.
charles ison
02-06-2008 22:45:19
 Re: FORDSON MAJOR PARTS in reply to dromonedog, 01-27-2008 15:42:58
For sourcing some fordson parts ,CNH have a gold parts scheme , and their electronic parts catalogue PAL which your local dealer has, has a special section ( in the useful information menu) with listing of all parts, which include fornt axle parts. If they have the older parts catalogues then by entering the part numbers into Pal the parts specialist may be able to source parts under their newer number. I was able to do this with the brake pedal return springs.
I hope this helps.
Bendee
01-31-2008 18:22:37
Try Bearco,I get all my parts from Bearco Aust, never been disappointed yet.Front axle bushes was one item.The biggest hassle was reaming.
Bill_S
01-28-2008 15:43:30
I'm sure you can get the front axle main support bushing from Ford New Holland, I ordered one today. $23 and change if I recall correctly.
Bill_S
01-29-2008 10:21:52
 Corrected Info: Re: FORDSON MAJOR PARTS in reply to Bill_S, 01-28-2008 15:43:30
Just got a call from the Ford New Holland dealer saying that the bushing that appeared to be available in their computer yesterday is not available. Sorry for erroneous info, in my haste to be helpful I got egg on my face. I'm expecting to be able to obtain what I need though from a bearing supply company just by dimension data. Good luck. Bill
tiresntracks
01-27-2008 21:57:19
In the topic below this one, is a place you can get used parts. This site, Yesterdays Tractors, sells some Major parts. Your local Case-New Holland dealer can still get a lot of parts for them. Here's a link to another one.
